Compleanni
Tanti auguri a:
ale2803 (49)
Degre63 (60)
Minisam (36)
Nei prossimi 7 giorni
lluca 79 (44)
OtoDD (49)
sandrinofe (47)
stefo.divita (35)
Teo_80 (43)
Alessandro Roncali (39)
kevin11 (42)
Marcus
weasel (42)
andydj31 (46)
duiliobozic (39)
JEENYUS (42)
just85 (38)
liuzziluca (17)
Mars31 (37)
Marzio RSV (48)
maxgazzella (54)
Robert
motarro (49)
thecrow89 (34)
Erbombardone (39)
hombre (44)
manöl (51)
oci76 (47)
BeppoS (39)
DTJ (34)
IndigoPi (38)
kold666 (45)
Millarddig (35)
pmancio (47)
bigfelix72 (51)
Castaway83 (40)
claudiopol (49)
Ex3m0 (45)
iceFactory (41)
kawa620 (61)
Nestordes (44)
O.oDin (36)
stewie91factory (32)
Tomberge (50)
WaReD (43)
 Allegati
Nome file
 AP8301 OEM RSV ...
Dimensione file:20.13 KiB
 ImageUploadedBy...
Dimensione file:425.2 KiB
 uploadfromtapta...
Dimensione file:221.29 KiB
 uploadfromtapta...
Dimensione file:168.15 KiB
 uploadfromtapta...
Dimensione file:190.73 KiB
 uploadfromtapta...
Dimensione file:180.9 KiB
 uploadfromtapta...
Dimensione file:214.03 KiB
 uploadfromtapta...
Dimensione file:235.35 KiB
 GUIDA MODIFICA ...
Dimensione file:1.74 MiB
 Istruzioni
Dimensione file:427.05 KiB
 processore dens...
Dimensione file:853.93 KiB
 ImageUploadedBy...
Dimensione file:176.51 KiB
 tuono v4
Dimensione file:48.74 KiB
 uploadfromtapta...
Dimensione file:44.94 KiB
 analisi_teorico...
Dimensione file:1.65 MiB
 uploadfromtapta...
Dimensione file:57.53 KiB
 uploadfromtapta...
Dimensione file:79.18 KiB
 uploadfromtapta...
Dimensione file:186.76 KiB
 uploadfromtapta...
Dimensione file:65.08 KiB
 aspect940
Dimensione file:72.33 KiB
 uploadfromtapta...
Dimensione file:93.3 KiB
 uploadfromtapta...
Dimensione file:46.08 KiB
 uploadfromtapta...
Dimensione file:67.75 KiB
 uploadfromtapta...
Dimensione file:100.88 KiB
 uploadfromtapta...
Dimensione file:100.81 KiB
 uploadfromtapta...
Dimensione file:70.66 KiB
 uploadfromtapta...
Dimensione file:49.73 KiB
 uploadfromtapta...
Dimensione file:36.1 KiB
 uploadfromtapta...
Dimensione file:116.36 KiB
 uploadfromtapta...
 Copia_di_Calcol...
Dimensione file:23.5 KiB
 uploadfromtapta...
Dimensione file:55.2 KiB
 TUONO NEW schem...
Dimensione file:82.51 KiB
 Attachments_201...
Dimensione file:953.82 KiB
 mille wiring di...
Dimensione file:4.52 MiB
 Akra 008
Dimensione file:291.24 KiB
 Istruzioni di m...
Dimensione file:1.16 MiB
 pistoni JE 97mm_s
Dimensione file:158.25 KiB
 disco_frizione_RSV
Dimensione file:182.36 KiB
 GRT_IWP189
Dimensione file:1.14 KiB
 black_MAX
Dimensione file:1.09 KiB
 ROAD BOOK IV RA...
Dimensione file:214.96 KiB
 Mappa descritti...
Dimensione file:12.5 KiB
 Ultimi iscritti
Nome utente Iscritto il
evatom 27 mar
Gustavo Lamussa 27 mar
gaiaazzola 27 mar
V4power 27 mar
salvo_0991 23 mar
  • ELIMINAZIONE DELLE RESTRIZIONI
Tutte le Aprilia RSV1000 (tranne quelle con motore Magnesium => RSV dalla 04 e Tuono dalla 06) vengono prodotte dalla fabbrica e consegnate ai rivenditori, munite di 3 restrizioni.
1) air-box
2) scarico
3) cablaggio centralina
Per rimuovere la restrizione presente nell'air-box vi consiglio di procedere in questo modo:
Per prima cosa procedete allo smontaggio della sella guidatore...
Rimuovendo le due brugole di fissaggio poste nella parte superiore del serbatoio, procedete ribaltandolo all'indietro e appoggiandolo sulla apposita astina sistemata nel vano portaoggetti.
Rimuovete il coperchio della scatola filtro, svitando le sette bruogole di fissaggio.
A questo punto vi troverete davanti ai cornetti di aspirazione e al filtro dell'aria.
Bene, quest'ultimo poggia proprio sulla restrizione che dovremo andare a togliere.
Per rimuoverla dovrete inclinare leggermente all'indietro l'air-box, quindi allentate la fascetta che lo fissa ai condotti delle prese d'aria e svitate le sei viti che circondano i cornetti di aspirazione.
A questo punto,guardando da sotto la scatola filtro, potrete svitare la vitina a croce che fissa da sotto la restrizione.
Rimontate il tutto ricordandovi di stringere le viti attorno ai cornetti di aspirazione e la fascetta sotto la cassa filtro.
La sella guidatore lasciatela smontata per quando agiremo sulla centralina. Una volta sistemata l'aspirazione, passiamo allo scarico dove la cosa risulta decisamente meno complicata. Dovrete semplicemente togliere il terminale e rimuovere quella strozzatura conica fatta con del lamierino traforato, posizionata all'interno del collettore.
Tale strozzatura e' fissata con due punti di saldatura che andranno fresati via. Una volta eliminati i punti di fissaggio e rimosso il cono, potete lisciare il tutto con della tela vetrata fine (6/800 va bene).
Ed ora diamoci all'elettronica..
Avendo precedentemente tolto la sella del guidatore, subito sotto noterete la centralina (ECU) protetta da una copertura in gomma grigia scura.
Rimossa tale copertura, vi si presenteranno due connettori (uno piu' grande dell' altro) pieni di cavetti. Scollegate quello a dx (il piu' piccolo che sta dalla parte della catena)...
...e con il tronchesino tagliate il filo BLU/VERDE (oppure il primo in basso a sx del connettore piccolo) sigillandolo con del nastro adesivo.
Dovrebbe essere il primo a sinistra della fila inferiore. In questo modo attiverete una mappatura adeguata alle nuove caratteristiche di aspirazione e scarico, che i cari e previdenti progettisti Aprilia hanno preparato e bypassato appositamente.
A questo punto re-inserite il connettore alla centralina e rimettete tutto apposto, copertura in gomma, sella, ecc..
 Login
Nome utente:
Password:
Ricordami
 Calendario
<< Marzo 2023 >>
Lu Ma Me Gi Ve Sa Do
1 2 3 4 5
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30 31
Vendita e Assistenza ufficiale APRILIA, PIAGGIO e MOTO GUZZI
